If you want more distance, get some that can use the various repeaters around. They can extend the distance a fair way - we used to get from Dandy area to Melton on a good day (roughly 50-60kms).
I've been looking at some Icom units, but they are fairly expensive... About the size of my current Nokia, so nice & easy to carry. They can also work at full power (5W) so a good 25km can be reached without a repeater.
About $360-$400 last time I looked.
  • Replies 70
yeah... those GME ones can use repeaters. The Uniden UH052XR is a good one too. RRP $419.00
As per the GME site
Duplex
Provides greatly increased range by allowing access to any of the hundreds of UHF CB repeaters installed around the country
Originally posted by acsplit
SKY031 you bag everything
Yeah, I'm gonna bag you in a minute, with lots of plastic and tape.
:D
I didn't bag anything. :cheers:
I was just saying, that as far as UHF radios go, theres no point in spending heaps if you're only using it for cruising.
GiJOr33 there aren't many active repeaters around Melbourne.
There is one in Berwick (channel 3), and one located somewhere around the city (channel 2) but due to the decline in the use of UHF radios, and the increasing cost of running a repeater, the repeaters have just gradually shut down and haven't re-opened.
(This includes channel 5 emergency which is no longer available)
Don't buy a radio just because it's advertising duplex as a feature, most of the cheaper (under $100) ones have duplex function as well.:D
if someone can get them trade then thats great as the bst discount i can do is $120 as i get them through my work (trade discount) but would need to purschase 10 or more
and yes you can get the incar base units which are a lot more in price
check out the web site
www.gme.net.au
any more queries email me
[email protected]
but acssplit is getting them.... So where do ya work Andrew
are you talking to me? cos my name is Andrew as well... and if you are talking to me... how do you know my name?!
I run my own business.... so just apply to the dealers when i need to.
GiJOr33 & acsplit are both named Andrew
ash3 and R31 Nismoid are both named Ash
Maybe we should just call everyone by forum names to avoid confusion. :confused:
Originally posted by RedLineGTR
i still would like someone who has used them to recommend one or maybe some ovious differences between them
redline i have used both and use them both frequently so pm me and i will tell you the advantages pros cons etc
i have to go to the movies now so i will reply later
but for the extra $25 gme is well worth it and i don't use the 38 ctcs encoding feature either
that would make the Uniden one the pick of the bunch with 2w of power... extra distance rather than private encoding
what if there are lots of people and you want your own channel? cos a cruise will mean plenty of people with cb's and if you want a channel with you closer mates, you can enable the ctcss and have one.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
