If you want more distance, get some that can use the various repeaters around. They can extend the distance a fair way - we used to get from Dandy area to Melton on a good day (roughly 50-60kms).
I've been looking at some Icom units, but they are fairly expensive... About the size of my current Nokia, so nice & easy to carry. They can also work at full power (5W) so a good 25km can be reached without a repeater.
About $360-$400 last time I looked.
  • Replies 70
yeah... those GME ones can use repeaters. The Uniden UH052XR is a good one too. RRP $419.00
As per the GME site
Duplex
Provides greatly increased range by allowing access to any of the hundreds of UHF CB repeaters installed around the country
Originally posted by acsplit
SKY031 you bag everything
Yeah, I'm gonna bag you in a minute, with lots of plastic and tape.
:D
I didn't bag anything. :cheers:
I was just saying, that as far as UHF radios go, theres no point in spending heaps if you're only using it for cruising.
GiJOr33 there aren't many active repeaters around Melbourne.
There is one in Berwick (channel 3), and one located somewhere around the city (channel 2) but due to the decline in the use of UHF radios, and the increasing cost of running a repeater, the repeaters have just gradually shut down and haven't re-opened.
(This includes channel 5 emergency which is no longer available)
Don't buy a radio just because it's advertising duplex as a feature, most of the cheaper (under $100) ones have duplex function as well.:D
if someone can get them trade then thats great as the bst discount i can do is $120 as i get them through my work (trade discount) but would need to purschase 10 or more
and yes you can get the incar base units which are a lot more in price
check out the web site
www.gme.net.au
any more queries email me
[email protected]
but acssplit is getting them.... So where do ya work Andrew
are you talking to me? cos my name is Andrew as well... and if you are talking to me... how do you know my name?!
I run my own business.... so just apply to the dealers when i need to.
GiJOr33 & acsplit are both named Andrew
ash3 and R31 Nismoid are both named Ash
Maybe we should just call everyone by forum names to avoid confusion. :confused:
Originally posted by RedLineGTR
i still would like someone who has used them to recommend one or maybe some ovious differences between them
redline i have used both and use them both frequently so pm me and i will tell you the advantages pros cons etc
i have to go to the movies now so i will reply later
but for the extra $25 gme is well worth it and i don't use the 38 ctcs encoding feature either
that would make the Uniden one the pick of the bunch with 2w of power... extra distance rather than private encoding
what if there are lots of people and you want your own channel? cos a cruise will mean plenty of people with cb's and if you want a channel with you closer mates, you can enable the ctcss and have one.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
