This question may seem a little jewish, but here goes...
Are there any injectors that are standard equipment on another car that would work well as an upgrade for a mildly modded 33 GTS-T?
Further more, any truth to the rumour that XR6T injectors will work? I understand that the 33 has 'side-feed' units, am not sure what the XR has, but any input would be great. I am aiming loosly at around 250rwkW, not fussed, but dont want to starve things.
https://www.sau.com.au/forums/topic/175348-r33-gts-t-injector-options/
xr6T injectors are top feed, you can buy adaptor rails to run topfeed on rb25 but then you needa change injector plugs etc, or you could try source 6 jdm s15 injectors which are around 480cc? correct me if im wroung that should supply that power level?
Thanks guys, :( I would never believed that the squirters on a 2ltr 4-pot are that big! What would you expect to pay for these?
And do you know of anyone who has run them before? I'd be keen to know their limits, naturally, without finding out the hard way!
Yeah ask me !
Haha.
I would rate them at 450cc.
Getting tuned tomorrow hopefully (take 2 with a REAL AFM) with a HKS2535 and all supporting mods.
Supprised by the size of the injectors hey?
Wellllll.....
2.5 / 6 (cylinders) = 416cc per cylinder
2.0 / 4 (cylinders) = 500cc per cylinder
Not so confusing now is it ? :w00t:
Yeah, so easy swap out .....(DIY available in the appropriate sub-section)
And heaps of info .... http://www.skylinesaustralia.com/forums/in...146846&st=0
And 2 injectors for sale right here matey $125 delivered
Edited by Birnie
Cheers mate...still thinking i might go the top feed 660cc siemens that ive been looking at as im probly gonna be chasing around 300rwkw eventually.
problem is my stock injectors are nearly maxing out at .8bar on the stock turbo.
hopefully an 040 pump will fix that.
hey mate, why dont you just go for drop in side feed injectors instead of top feed, such as tomei or nismo 740 cc injectors. Slide has them for $895 delivered. do you know what duty cycle your injectors are running. id say get a fuel reg as well if you want a quick fix solution to your injectors maxing out
I got one set from Slide Imports, brand new with a GTR R33 fuel pump for about $300
But thats for brand newies with all the rubber thingos to go with, see pics in the s15 thread i posted earlier.
2nd set from a written off S15 in Aus.
$250 delivered for 4 out of a 2002 model.
You should be able to pick up 2 sets for about $400-$450 and then try selling 2 like me and come out about $300 out of pocket which aint too bad
forget any other model eg. s12/13/14, no good to you if they are standard injectors,
s15 manual ones are the only 450-480cc injectors.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
