Yes the car was up to operating temp and running and it was steady at 18mm HG. There was no change in idle speed and no change in 02 reading to indicate additional hydrocarbons, i used consults to dignose.
I have tested the ic form the turbo to TB, held 50 psi no loss.
I did also spray all the IC connections and IC itself, no change.
Edited by WogsRus
  • Replies 69
Did you pressure test the plenum? Open the throttle body next time you do the test so it pressurizes the plenum too, so if there's a leak in there you should be able to hear it.
Well, myself having not actually had a look inside an RB before, in theory that sounds correct. But should they be both open at the same time at any time?
You don't have an adjustable exhaust cam do you?
Either way, If there's a leak somewhere, then wasted air = wasted fuel.
there is a certain amount of valve overlaop on the exhaust stroke from memory, i will rotate the cams to get the beast seal and see.
I agree that wasted air = wasted fuel, but it's a bitch trying to find it. LOL.
i will get another mates guage just to make sure mine is correct. The stock guage sits about half way between the bottom line and the first line from the bottom. so about -5 or what ever it is.
Green means GO, Red means Go SLOW, lol.
Well my drive to work is 8 minuts at best, and i live in hobart which is hill central so it's hard to stay of boost all the time.
I do give it a squirt now and then, but not like i'm going sideways evewhere.
When my wife drives the car, she gets no better ecconomy then me, so either the car is screwed or she's a lead foot. LOL.
Edited by WogsRus
wind your boost down. you are using more fuel because you are running higher boost. the more air you put in the more fuel that has to go in to keep the afr's the same. you would probably benefit from a tune, but you still won't be able to get the fuel economy of someone running 10psi because they aren't putting as much air past the afm.
Arround touwn i run 10 or 7 psi depending, and ecoconomy stil shit. The tune was done at 15 psi and rechecked for lower boost levels and all showed to be fine.
Anyway tune next week so interested to find out what it is.
Corinne says:
As much as I'm not a fan of the PFC, you should get one. - That's because you can't tune them properly wink.gif
You should use one device to control one element, at the moment you're using 2 devices to control one element. Not smart. They tangle each other up.
That and you may have lost your map in the SAFC - SAFC's are shit to tune.. they are very rough.. you can never get those flat spots out of them.
Corrine, PFC are frigging annoying to tune off of that little hand controller, especially when attempting to use map tracer at the same time to look where the engine is sitting, and then adjusting that!
And I never said the SAFC was good, I said it was possible he had lost his map from it.
Corinne says:
Who the heck tunes off the hand controller? You use the datalogit, a laptop and a wideband to tune them properly.
Edited by KeyMaker
