G'day.
After a couple of months of trying to get my CD stacker to work (the Jap one that came with the car & is missing a cartridge), I've decided to bite the bullet & get a new stereo.
I don't want to win any competitions & I don't care whether I have the latest, greatest sound system.
I just want a good quality mid-range CD player & radio in the car, playing through the existing speakers.
SO, do any of you guys know how I go about working out which systems are best value?
Does anyone have recommendations of single DIN CD/radios?
Any advice would be welcome. :D
Cheers - Sven :P
https://www.sau.com.au/forums/topic/17543-which-head-unit/
i'm starting the like the alpine range now .. they just keep looking much better and better the more i look at it ... i was going to try and buy a jvc .. but now i'm going to get the alpine i think .. but yeah who knows my minds always changing.. but u still can't beat jvc for bang for buck!!
https://www.sau.com.au/forums/topic/17543-which-head-unit/#findComment-365474
figure out how much you want to spend and we might be able to help you more.
JB HiFi are always a good place to start. They have a wide range of headunits and are very reasonably prices and generally bargin.
Play around with them and find out which features you will use then find a unit that suits you. Never pay the listed full price at any store, there are always better prices to be had!
https://www.sau.com.au/forums/topic/17543-which-head-unit/#findComment-367690
at first i wanted the new jvc HU with the blue display ... it looks ok on paper ... quite nice actually but when u have a closer look at the display its not very good at all ... and lets down what should be an excellent deck!! i then thought about pioneer but then i thought that they were sooo common and if u play with the knob on the right hand side of the 03 range u will find that its pretty dodgy ... so then i had a look at the alpine ... it didn't have the rice features like the animations ... but then i thought ... but hey its got blue and green lights ... thats rice enough :D ... so yeah i'm defintely going for alpine based on looks and features ... i dont' think u can go past alpine on features for actual audio ... but yeah u gotta look and have a play around with everything whcih i've done ... and yes i didn't even give sony a chance.. i think they look ugly and don't even come close to having as much features ...
https://www.sau.com.au/forums/topic/17543-which-head-unit/#findComment-367707
yeah i just installed my alpine yesterday too ... great unit ... and pred has a good point ... its made in china ... i think build quality is good ... screen is dammmn brigth and ricey ... just the way i like it ... :) damn good for 650 delivered :D ... oh yeah ... both FM and AM work perfectly :D ... who said AM channels wouldnt' work???
https://www.sau.com.au/forums/topic/17543-which-head-unit/#findComment-398981
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
