  • Replies 157
yeah got very packed at 7ish....got 2 runs in beofre 7 and the only had 2 more and left at 9.30 cause timing was playing up and i wanted to beat the rush...
got a new pb but left the slip in my brothers car so i can only go off memory....
60t
1.951
330
5.560
84.5mph
E/T
13.180
105mph
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3224891
the night was good....the track was exceptionally cold and even a decent burnout didnt help....absolutely no traction through 1st & 2nd.....pretty hairy as i hit second hard and the backs light up as usual but stayed light up and ass was all over the place. backed off and tried again and still light up so I just cruised for a 13.780
Next run track alot more heat so I bogged down off the line and ran a 13.3....next one it was rushed through burnout so bagged it up off the line....13.290
Final was best 60ft and was sort of a bog down but not much more i could have squeezed out of it.....found out that i didnt have boost as high as i thought and still hade my sub in my boot....might have been the difference from a 12 sec pass...
can anyone tell its been a while since i went to wsid....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3224895
Haha...
13.180 60ft was 1.951, which is my best so far...but boost was a little lower then i wanted...thought i raised it to 12psi but didnt save it...
yeah i remeber back when i was beating u.....now i got no chance.....
i gonna be pumped when i eventually hit the 12's....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225602
At least another PB Brendan what 60ft did you run for the 13.180?
I reckon the 12's is just around the corner
and yes you haven't been for a while did me running 12's first put you off? haha j/k :)
What did you run Ray?
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225650
I ran to the gym instead to lose some weight (further weight reduction),
IF THE WEATHER FORECAST is good i'll be going next week..
Last time it just shitted me when i got the car all ready even put the drag tyres on and called WSID at 5pm
(race meet for tonight has been cancelled) just my luck.
Either way Brendan at least everytime you get out there your setting a new PB :) keep up the good work
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225773
60t
1.951
330
5.560
84.5mph
E/T
13.180
105mph
hey man, i was the guy who talkd to ya when u finishd ur run!!
good stuff on the 13.1 i saw it from the grandstands
after seeing ur effort im deffintaly gonna get some slicks ay!!!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/2/#findComment-3225970
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
