  • Replies 157
Thanks...
nah on very bald and old set of nittos....but when i heat them up with a decent burnout they are super grippy...
the 1.911 launch i completely changed my technique....increased it from 3500 to 5500-6000rpm....tried the two stage clutch and it felt soooo much quicker....
i used to hit it pretty hard and thats why i could only launch at 3500 cause any more would just bag up off the line....
tried the new technique and didnt even get it perfect and smashed my 60ft time....
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237426
Cheers!!
Tried the technique u explained to ray and loved it...first try at it i smashed my best 60ft...
Which technique? Adrian PM me if it's a secreat I wanna know lol
We'll I changed my technique last time at the drag day and smashed my pb/60ft by half a second twice in a row then it rained out !! :ninja:
woooooo Vic!!
No hmmmmmz'ing
I'll drag ya! woooooo :ninja:
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237688
My car makes a bit over 200kw....maybe a lil more cause i increased boost a little bit.
dont know if the car gear is a waste of time....if its already at its optimum it will be $300+ wasted...
but practice is whats helping me the best....been just 2 weeks in a row and keeps getting quicker...
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3237783
Black...someone said it was gtst....benm had a chat to him i think....
think it was this guy, first run he ended up on the other lane.....scary!!!
the guys name is marko its a black 32 gtst with a rb25 it has gt 35 40 and nos not bad at all for a stand engine well done
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3238044
an update on my first 1/4 experience. think I was the only R34 there.
"consistent" disastrous 60ft time!
1, 4000rpm launch wheel spun all the way through first gear and most of second.
2.5 60ft, ET 14.3 @ 108mph
2, 2500rpm launch (had a chat with Ben and was suggested to try with lower revs) bogged down big time
2.6 60ft ET 14.1 @ 109mph
3, best of the night 6000rpm launch, clutch back in as soon as I felt spin and then out (dont know what exactly happend happend all too quickly)
2.6 60ft ET 13.7 @ 111mph
had to go to the city afterwards so only had 3 runs, but highly doubt i would have improved on the time had i stayed. conclusion was that it was an exciting first drag experience and I have no idea how to launch this car! :D
now can anyone explain the 2rismo 2 staged launch techique (I would pay you to learn it :D )
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240000
Forged: was your car the Silver r34 gtt?
2.5-2.6 60ft is SHOCKING,
How much power does the dyno say your car makes? 111mph is quite high
What brand/size rubber you running on the rear?
Did you try lowering the tyre pressure for the rear tyres and attempt to do a decent burnout to heat em up?
Usually for someone with those 60fts, what you should of tried is just a normal take off (as you would do on the street) and i reckon you would of gotten better times, then trying to launch it at this rev or that rev because the tyres weren't up to the task. It happened with one of the guys in an r33 gtst he was trying this and that and his BEST run of the night was when he just drive it off the line as per normal as if he was on the street :D
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240039
yeah the silver one was mine. i saw a few white 33s there but didnt get the chance to talk. which car were you in?
it makes a bit over 250kw on the dyno so i was expecting much better times. obviously something wrong with my technique.
tyres are bridgestone s03n 255/17 at the rear. i lowered them to 24psi but did not do any burnouts been told they(burnouts) are ineffective with street tyres.
ive tried a normal take off which was my second run, launched with 2500rpm (as what Ben told me to try) it bogged down intially then as soon as it hits 4000-4500rpm (full boost) wheel spin began again until second gear :D
https://www.sau.com.au/forums/topic/175434-wsid-117/page/6/#findComment-3240163
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
