  • Replies 157
Brendan, I used to be the same man!
I know a way of going quicker for me...selling my gtst and buying something else.
I was teh suxorz tonight
Legend - was nice meeting you, pitty bout your oil situation, everything all good?
A mate in his turbo mx5 was out to get a 12...but second run blew his diff d'oh
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3250391
haha I did Ray I did! :pirate:
But I was hungry... :blink:
I was suffering axel tramp so bad, best was 2.3 (my best ever when standard springs/shocks/clutch was 1.9) I even slipped the clutch out on one run as carefully as possible, and as it came out, went up in axel tramp again as I got onthe gas, so was on and off trying to control it (excuses excuses... :) )
tyres - dunlop sp9000 - 225/50/16 (brand new)
pressure was around 22psi
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3250419
Yeah was good meeting you to Chris, always nice to put names to faces .havn't looked to see where the oil was leaking from as yet but wasn't leaking when I got home and oil pressure was still good so bit of a mystery but I'll find it and be out there again to get that pb.Was happy with my first run of 12.5 though after so long.Putting pineapples in fixed my axle tramp problem in the drag position
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3250574
what boost u running? i thought u'd get alot lower....
let me compare ur slips to mine the next time we are out there...
did a pb while u were away....almost cracked a 12....
was it busy last night? how many runs did u get?
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3250894
Axle tramp bad ,it's where your tyre's bounce up and down when you launch it of the line and feels like the car is falling apart,you either have to power through it, which is hard to do as first instinct is to back off or back of and give it to it again either way you loose time
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3250925
Axel tramp....heard this expression before but can someone explain it?
Chris what time did u end up getting?
your wheels are turning at different speeds cause it to do what leg said... just power through it! Mine used to do it too... didn't do anything to fix it, it just sorted itself out!
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3251020
Oil Problem found, pumping oil out the rockers into the air box never had a problem with the old standard oil pump but the N1 pump must be pumping a lot more oil around the engine .Only loseing oil on the low side breather not the high side so will have to put a restrictor in that side
https://www.sau.com.au/forums/topic/175434-wsid-117/page/8/#findComment-3251883
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
