OK in my 33 GTS4 i got the stock cd/tape/radio unit
i had to replace the stock speakers cause the outer ring blew out from age
i had the same problem with the original speakers tho
The music sometimes will cut out on one speaker to a lower volume and shit
and it seems to only do it when going over bumps, any ideas?
https://www.sau.com.au/forums/topic/17557-stock-stereo-prob/
Sumo sounds like he is on the money. chances are the one of the connections isnt contacting correctly with the speaker terminals or there might be a problem with the acutal cable connecting the headunit and speakers. (more unlikely).
Spend a few minutes to have a look over the speakers and test them before you put everything back together (eg. doors if you took them off).
:D
https://www.sau.com.au/forums/topic/17557-stock-stereo-prob/#findComment-367676
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
