Hey Guys
Price Drop $75
- I have for sale a wing to suit a R33 coupe'
- Located at Puckapunyal VIC (Seymour is the nearsest town),
- Its in good nick apart from a couple of minour scratches and Its Painted 1n3 Ford Blue,
- Pick up Prefered because its too hard to organise freight from a military base and i dont want it
damaged in transit.
- May Deliver - Depends Where You Are
Contact me on 0409348752
or fire off an email to - [email protected] (dont laugh I made it when I was about 15) :)
Regards
Andrew
Edited by zebra
https://www.sau.com.au/forums/topic/175573-r33-wing-fs/
Just Realised Why I dont have the bolts for it.
The two drivers side bolts have snapped off.
Just Throw an offer at me now.....first to pick up can have it.
My Phone number is 0409348752
https://www.sau.com.au/forums/topic/175573-r33-wing-fs/#findComment-3242382
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
