RDA and DBA are punched out from the same factory...
When i was looking up part numbers they were in the same book and under the same number :P
My brother runs ABS down here in Tassie and its interesting what i've found out while looking into brake/clutch upgrades/problems.
When i was looking up part numbers they were in the same book and under the same number :lol:
Then use the RDA. The DBA 4000's crack from the return slots. I have lost two rotors to this - one from & one rear & both with minimal wear.
What pads? I've cracked a few DBA4000's. I've heard but not looked up myself that RDA don't do 310mm replacement rotors for my car but considering trying to space out to 324mm to use R33GTR rotors.
Are there any standard sizes a little bigger than that I could maybe space out to? What do R34 GTR's run?
Pads, rears were Bendix Ultimates & fronts were Ferodo DS2500's. I will post up a pic when I get organised.
  • 1 year later...
id prefer the rda over the dba slotted rotors. me and a friend went for a drive on the weekend down 2 nowra 4 the airshow same cars r34 gtts same brake fluid both have ebc redstuff pads only difference his car has dba and mine rda. i fitted and bled the brakes on both at the same time and when we were heading down there and we got stuck behind a horse float goin down the hill at kangaroo valley from moss vale and when we got 2 the bottom my brakes were fine but his had a bad vibration. we swaped cars and i drove his and the steering wheel was vibrating ab out 2 inches each way and it was hard 2 hold the wheel when braking but cleared up after a while of not braking 2 much. hope that helps.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
