i dissagree!
seeing alot of stock R32's and Stock R33's at dyno days (i know they are in shoot out mode)
however
stock R32 gtst's ~ 130rwkw
stock R33 gtst's ~ 150rwkw
that is what both my stock r32 and r33 ran! alos many of my mates!
https://www.sau.com.au/forums/topic/175698-rwkw/#findComment-3218652
i dissagree!
however
Those figures are a little high, most cars at dyno days aren't stock(almost none) all it takes is a cat back to give it that little bit more. Got to be happy that your making a bit more, the only time an r33 seems to make that power stock is when the fuel pump is dying, as it leans the mixtures out a bit.
https://www.sau.com.au/forums/topic/175698-rwkw/#findComment-3218897
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
