need some advise from those in the know.
I'm looking to sell my stag and the bloke who's interested wants to have it RAC inspected.
my car hasn't given me any problems at all since i've owned i dont doubt that it'll pass any mechanical check...my worry is that it has an aftermarket boost controller and safc fitted...will these show as a defect in the check?? Does the RAC check for mechanical soundness or does it also run a compliance sort of check in the vehicle? ..would hate to have to return everything back to stock only to have the buyer pull out.
cheers
https://www.sau.com.au/forums/topic/176039-rac-check/
The rac check will note the mods on the car as "observations" it will state along the lines of " observation: boost controller fitted to vehicle"
Just had one done on a 180 with aftermarket kat back and thats what the report had on it
cheers mate.
did they do a compression test as well?
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3222673
You might want to mention to the bloke that the RAC won't know their arse from their elbow when it comes to imports. If the guy is serious, tell him to talk to one of the guys at autoworx or any of the other workshops in WA (I'm sure Brad will be able to tell you which one to use :nyaanyaa: ). At least then they know what they are talking about.
I contacted RAC about insurance when I bought mine, they had no idea what it was and told me they wanted the car fror 3 days for assesment before they could give me an answer.
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3222679
No compression check. They do drive it for a bit and check for smoke
Sure they don’t really know as much about imports as the workshops do and I had the same opinion that it’s not worth doing the test until I had one done on my 180. They give you a very good indication of the condition of the car and they do go over it with great detail. The report itself is a very detailed 2 page summary and tells you the overall condition and the condition of separate components, i.e., Engine, electronics, drive train, cosmetic... etc
Not good if your car is stuffed though ;)
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3223176
Sure they don't really know as much about imports as the workshops do and I had the same opinion that it's not worth doing the test until I had one done on my 180. They give you a very good indication of the condition of the car and they do go over it with great detail. The report itself is a very detailed 2 page summary and tells you the overall condition and the condition of separate components, i.e., Engine, electronics, drive train, cosmetic... etc
What do RAC checks go for nowadays? I paid 180ish for my Stagea and that was a comprehensive 5 page report with compression test, paint test etc etc. Jeez that guy was picky too! It was worth it as I made sure the dealer who sold me the car fixed up ALL the minor problems before the sale.
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3223463
thats strange..i mean how could they possible tell the condition of the electrics just by testing...i mean you can say if they were working...but surely without some diagnostic plug in..u couldnt tell if an electrical component was on its way out.
i really dont mind them doing a rac inspection..in fact given the reverse...i would do the same...but i certainly dont want them holding my car for 3 days to do an inspection....what a pain.
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3223685
we had the skyline RAC checked for the guy that was interested in buying it....it didnt take 3 days..they arrived at 9am in the morning and left just after 12.00...he spent ages in our driveway going over it and took it for maybe a 10 minute drive most...the things that came up in the report were things that we already knew of, but actually gave the guy piece of mine that there was nothing wrong with the car except a few cosmetic marks....if you have nothing to hide then get them to arrange the RAC inspection at your house and you shouldnt have an issue, or alternatively if your so worried about the RAC get an import dealer/mechanic to go over and they will search every little thing and note every detail they find...its all worth the money :dry: especially if your car passes and it means you have a sale on your hands and if not you keep the report and you can show potential buyers the same report
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3223813
the 3 days was to asess it for insurance because they had nothing like it on their records, not to provide a pre-purchase inspection.
I still reckon you would be better off getting the inspection done by an import workshop. They are a lot more likely to know where to look for problems (like rust under the wing mirrors) and they will give a prospective buyer a fair bit more confidence.
https://www.sau.com.au/forums/topic/176039-rac-check/#findComment-3223899
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
