As most would have seen recently my r32 which ive owned for a great 3yrs has finally been sold..
It was a sad moment to part with it but it has now made way for my R33 GTST i just picked up last night for a bargain price *hush hush* hehe
Pics should be up on friday give u guys a look at her
Shes out of rego at the moment gotta go blue slip her tho i hate the things lol
keep you all posted and ill organise a newy and coast meet when my licence is returned to me end of october :nyaanyaa: damn cameras lol
happy crusing ladies and gents :P
https://www.sau.com.au/forums/topic/176095-just-joined-the-r33-club/
i love the look of the bonnet tho problem with it is filling the coils up with water when we get lots of rain lol
any thoughts on keeping it there but possibly redirecting water flowing inside?
Duct Tape & Cable Ties?
looks tidy
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
