For Sale: 1996 S2 R33 Skyline GTS-T Manual in Silver
* 90,000 kms
* Purchased completely STOCK STANDARD, even had stock exhaust. Was fresh import with compliance plate date 03/2007, so I am first owner
* Items done since purchase in march: Turbo back exhaust (trust titanium & jjr dump/font pipe), window tint, clear side indicators, timing belt, water pump, fuel pump (walbro), coolant flush with new thermostat, fuel filter, oil & oil filter, K&N pod filter, platinum spark plugs, splitfire coil packs, injector clean, new clutch (heavy duty), JVC head unit, alpine 6-inches all round. All engine items were done because i'm fussy and didnt want anything going wrong, not because anything was stuffed. All done professionally by a performance garage with thousands in reciepts.
*This is a deasent example of a clean car, it is in excellent condition inside and out ( apart from few small holes in dash where something was, before it got imported )
*Purchased from Power Road Car Sales in Melbourne in March 07
*Genuine reason for sale: need a 4 door sedan (large) for upcoming work commitments, which sucks but i cant afford both
- Pics up as soon as i can, but for now so you have an idea, its stock standard looking with tint and side indicators.
$14,900 with roadworthy and rego till march 2008
if interested please PM me,
Cheers,
WALTA
Edited by walta
I went to Power St Car Sales the other day didn't see anything that wowed me I'd might be interested when you post pics
i was the same when i went there, but the one i bought was actually in really good nick, i looked at a black 4 door but it had stains on the seats and needed skirts, back bar, and front bar repainted, so i bought the one i got, ill hopefully get pics up sunday
  • 3 weeks later...
Is this over priced or something???
Months ago....NO!
Lately.....YES
Imports are just hard to sell at the moment, This forum has some fine examples of that!!
Good Luck anyhow :)
that is sooooo cheap probably cheapest series2 in australia (that is manual )
not really there are couple of mspecs floating ard in carsales for 13000 or even lower and with longer rego...its really sad to say imports are finding harder to sell, and the p-plate law juz worsen it =(
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
