Hey Guys,
Just got a problem which some of you might have the answer to.
This is regarding the installation of a head unit.
I have no constant power wires behind the din, I only have the acc wire. Can I run another wire striaght from the battery to the head unit as a constant power (with fuse) ? Or will that drain the battery?
Another question that I've got is how do you make another Acc power supply? I want to use if for fog lights
Any help would be awesome.
Cheers
Kslim
https://www.sau.com.au/forums/topic/17635-electrical-problems/
"you can run it from directly from the battery just make sure when you shut down the ignition off you turn the deck off..."
So does that mean that the head unit will turn on with out ignition??
I thought it wouldn't turn on without ignition because I can use the ACC power supply thats there...??
thanks
To create a new acc line from the existing one to run heavy current devices, all you need is a relay. See attached pic for wiring details. Since the middle pin (normally closed contact) is not used, you can use a single pole single throw (SPST) relay. You can get an 30A SPST automotive relay from jaycar for 6 bucks. A matching socket with cables is also available for $5.90.
Cheers.
It is best to always wire the permanent power wire (usually the yellow wire) directly to the battery using a decent gauge wire fused as close as possible to the battery because most of today's high powered headunits use this wire for their main power. the acc. wire (red) is only to turn the headunit off when you turn off the acc.
the acc acts as a turn on wire for the headunit. It is much the same as a remote wire from a headunit is to an amp, it tells it when to turn on so the amp isn't drawing power from the battery when the car is off.
if you are running a headunit and you intend to use the internal amplifier (eg. run the speakers off the headunit) then i would recommend running a new fused power wire directly from the battery. However if you just intend to use the RCA outs from the headunit to run an external amplifier it probably isn't necessary to upgrade the power wire and you can usually just split a wire off the cigarette lighter. (be sure to do this safely).
If in doubt, run a new wire:)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
