Bee R make a rev limiter and launch controller that you can install in cabin.
It basically allows you to set your desired rev limit. Unlike factory rev limiters which cut fuel, this one cuts ignition, so fuel still goes through.
When they hit the hot turbo they ignite and u can get your flames comming out of the exhaust like the movie.
However it will drastically shorten the lifespan of your turbo.
  • Replies 121
Originally posted by Zensoku
but that is what the "ricey arming red missile switch" is for!:bahaha:
Maaaan I had that shit on my strawberry face 180 back in the day as a kill switch for my amp. Back then the only place you could get it was at Jaycar, and it fitted a corresponding PSTN switch... thought I was pioneering shit, until at autosalon my car was right nex to sum otha f00 who had done the same thing... so naturally I had to remove it...
Now every shop carries it. :P
BTW kidd... here's an interview with Lieberman... it belongs to Hiro from Motorex.
http://www.nissanperformancemag.com/march03/lieberman/
NPM: Was the new color scheme strictly chosen for use in the movie "2 Fast 2 Furious" the sequel to "The Fast and the Furious"?
As it will appear in in the upcoming movie "2 Fast 2 Furious"
C.L.: Yes, The car is silver in the movie. It looked awful, so we just got done painting it back to blue. Why anyone would want to put SS Camaro stripes on a JDM Skyline is beyond me, but the guy designing the graphics (Keith Burns, Prod Designer) hates cars and generally needs his head examined when it comes to car accessorization, just my opinion.
NPM: Sounds as though you weren't too happy with their choice and couldn't wait to get it back to the original look afterwards.
C.L.: The gray/blue thing was ok with me. But the aforementioned clueless designer covered my carbon fiber nitrous bottles with chrome vinyl…it was the first thing I changed when I got the car back. In fact, this dude covered every carbon fiber surface with colored vinyl. As you can tell, I'm not very happy about his choices
Hahaha spoken like a tru Skyline owner :P
watched the movie and was also eager to find out what fuel they run. as for those flame thrower kits i had one on my old car and it was the spark plug typr but only ignited the fuel on with the switch was pressed and also caused the ignition to die ( like doing a key banger with out the stress) as for the REAL car comment if you watch a top fuel drag car they have continuos flame for the hole time they drag. aren't they real cars NZM.031
my skyline can pop flames and nearly all the turbo cars i know can pop flames run a different fuel like menthanol or high grade av gas and you'll get more flames
Originally posted by RedLineGTR
the non funny thing would be if someone had it setup like that and one of his mates didnt know imagine if he pressed them...the plenum would go pop..
Yes, I've lost count of the number of plenums I've heard of going 'pop' from nitrous use. Also imagine what would happen when the car finally rolled to a stop.. why at least 500 porcupines would then drag the owner and his friend from the car and beat them senseless. Because as we all know this is what happens when you use too much NOS. Just like parts of the floor falling off really isn't it, you know -- the excess NOS finds it's way to the seam welds and unwelds them.
Zensoku,
You should put little NOS stickers on the horn buttons and charge twice as much for the steering wheels I reckon.
Like it isn't already happening in Sydney and the Gold Coast.. its on all the Wannabe rice boys shopping lists...
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
