The convertable is known as a Mitsubishi Spyder, from memory is a Turbocharged 2 litre V6 4wd.... The Coupe is an Eclipse, which uses the Turbo V6 2 litre with 4wd, but I may be wrong about the new Spyder, they may have changed it recently. Dunno, and the 2F2F site doesn't help.....
S of S
  • Replies 121
from that NissanPerformanceMag interview:
________________________________________________
NPM: Have you had the chance to Dyno your car?
C.L. No, but according to MotoRex, it made about 500hp without the nitrous. In my opinion, it's more like 440 or so.
woohoo - 500 whole horsepower? All at once???????? From an R34 GTR??!?!?!?!?! Amazing. We'll all be well impressed with that.
I'm sorry to be a downer, but I just can't get myself excited about a street-racing movie starring a GTR with 500 hp. It wouldn't even get a look-in at a Japanese "light-tune' street meet. That said, I enjoyed the first movie, but I think I'll wait till this one comes out for rental.
do you know how hard it is to make a honda hit 500hp man? you gotta put it in context. Sure you can make a GTS hit 500hp with the amount of money they spent on that GTR, but still... meh, think I jus contradicted myself... fvkkit... its like watching transformers man, like its all cool and shit but you know optimus prime ain't big enuff to convert to a semi trailer.
The "Self-fixing" frontbar is when the EVO ram-raids the gates into the boat shack on the waterfront when Brian and Rome R racin the otha dudes to get that "package" for Verone. Next scene after he ploughs through the gates it is virtually unscratched.
The Convertible Spyder was also briefly in the first film on the 1st drag nite when everyone is lining the streets.
I know it's hard to get 500hp out of a Honda, but it's not even stretching a GTR, so I just can't get excited about it.
I'm not sure if your meaning was this or not SydneyKid, but the mitsubishi Eclipse was the coupe, and the drop top is a version of the eclipse, called the mitsubishi eclipse spyder. The spyder in the movie seemed like the 4th gen of eclipses, so it uses a 2.4L inline 4, or a 3L V6 FWD, no turbo came out for that car, for that generation, nor did a 4wd version. The previous generations used the 2L turbo 4g63 from the evo's, and that was 4wd.
Ah, ok. I get confused with US Spec Mitsu's. They seem to change so often, and well before i can keep up. I now wanna know how a 2.4litre FWD can kep up with an Evo VII..... But uour right, it is a 2.4litre 4....
S of S
did u know they are maiing the a new movie for transformers...transformers are the best.
2 fast 2 furious was SHIT.....they cars are all teeny bopper poxy shit....id only watch for that fine ass latina...WHOA...cant john howard start getting latina migrants here instead these afghans...!
yeah new transformers movie coming out, and its not cell animation based, its like semi animated (which means people acting in beast wars style shit) by the looks of it.
And suki sux teh cawk... there's much much better looking asian chix they coulda cast. Or a korean chik... mmm inoccent good looks of a jap and tenacity of a chinese...
to clear up the convertible debate, it is known as the Mitsubishi Eclipse Spyder, and yeah it is that latest generation eclipse in the U.S but the one in 2f2f has a turbo kit in it :) i'm pretty sure greddy america make bolt on turbo kits for the eclipse spyder :)
adrian :)
it's about 20kUSD, or there abouts, it would have been about 40k here, if it ever came out. Hmmm, turbo kit, yeh, noticed it had the BOV sound, but, i didn't really expect it to be turboed, thought they just added those sounds for effect.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
