Guest SadisticRage
As a suggestion, Mintex M1166.
Not as hard on discs as Green Stuffs, will handle track temps without a glitch and are fine from cold.
The only downside is a brake squeal similar to what many seem to experience with Bendix Ultimates although it is only for the first 3 or 4 applications until they get some heat into them.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-33931
Hey this is like only sorta related to the pads..
but which pads besides the greenstuff..give off the LEAST brake dust??
Ive got stock nissans at the moment..and stock nissan rims..and i never get much dust on them at all..
i love it!!! (cuz i hate dirty rims)
but a mate of mine has bendix ultimates..and his rims are premanently dirty
hgehe
mc
:shake:
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-36641
I've got a set of Racebrakes on my front, they give quit of a bit
of dust, but then again i do give them a hard time. I'm more
worried about slowing down when I want, rather than some
dust which is easily hosed off anyway. :uh-huh:
Oh and yes.. Any of the pads mentioned are better than the
stock pads. Well in my experience anyway.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37125
I'm running racebrakes RB74 compound on the front and racebrakes comp2's on the rear. I got my discs machined last week then changed the pads. I haven't really given them a hard workout yet but they feel a bit more responsive than the factory pads I had in there. I'll be getting on the track in 2 weeks so I'll find out how they perform then :)
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37664
I have found some sweet pads that I am using and after using many different pads on all my previous cars I can easilly say that these are the best pads ever. I have a full set of WedSport brake pads, these are awesome and I believe that Nengun sell them. I got mine from Japan and can't remember how much they cost but they aren't cheap.
Even from cold they are awesome and can easilly pull the car up from 200+ km/h.Must admit tho that they are very aggresive and I need to have the disks machined once a year.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37746
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
