Guest SadisticRage
As a suggestion, Mintex M1166.
Not as hard on discs as Green Stuffs, will handle track temps without a glitch and are fine from cold.
The only downside is a brake squeal similar to what many seem to experience with Bendix Ultimates although it is only for the first 3 or 4 applications until they get some heat into them.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-33931
Hey this is like only sorta related to the pads..
but which pads besides the greenstuff..give off the LEAST brake dust??
Ive got stock nissans at the moment..and stock nissan rims..and i never get much dust on them at all..
i love it!!! (cuz i hate dirty rims)
but a mate of mine has bendix ultimates..and his rims are premanently dirty
hgehe
mc
:shake:
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-36641
I've got a set of Racebrakes on my front, they give quit of a bit
of dust, but then again i do give them a hard time. I'm more
worried about slowing down when I want, rather than some
dust which is easily hosed off anyway. :uh-huh:
Oh and yes.. Any of the pads mentioned are better than the
stock pads. Well in my experience anyway.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37125
I'm running racebrakes RB74 compound on the front and racebrakes comp2's on the rear. I got my discs machined last week then changed the pads. I haven't really given them a hard workout yet but they feel a bit more responsive than the factory pads I had in there. I'll be getting on the track in 2 weeks so I'll find out how they perform then :)
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37664
I have found some sweet pads that I am using and after using many different pads on all my previous cars I can easilly say that these are the best pads ever. I have a full set of WedSport brake pads, these are awesome and I believe that Nengun sell them. I got mine from Japan and can't remember how much they cost but they aren't cheap.
Even from cold they are awesome and can easilly pull the car up from 200+ km/h.Must admit tho that they are very aggresive and I need to have the disks machined once a year.
https://www.sau.com.au/forums/topic/1767-brake-pads/#findComment-37746
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
