I have for sale a variety of R32 and R33 items for which I am keen to part with:
R32 GTS-T
1. Factory exhaust from turbo dump to muffler tip (excluding cat converter) GC $200
2. GTR style rear wing (was on R32 GTS-T). Black. Has minor scatches GC $200
3. RB20DET remapped (Matty Spry tuned) ECU to suit stock injectors with modified garrett turbo on stock manifold and 20psi GC SOLD.
4. RB20DET coilpacks GC $30 ea or 6 for $150
5. RB20DET Air flow meter (mesh has been removed) SOLD
6. RB20DET power transistor GC $40
7. RB20DET crank angle sensor GC SOLD (I do have another if anyone is interested).
8. R32 O/F bottle GC $30
9. 3†dump pipe from turbo to cat (has some scratches) GC SOLD
R33 GTS-T
I have some parts remaining over from an R33 series 1 front cut purchased for an RB25DET conversion. I also have some parts from a series 2 RB25DET. Parts include:
1. R33 Series 1 Power steering rack with tie-rod ends GC $250
2. R33 series 1 (1 off) and series 2 (1 off) auto ECU GC SOLD
3. Brake booster GC $60
4. RB25 series 2 coilpacks (5 off) GC $40 ea or $180 for 5
5. Front discs with minimal wear GC SOLD
6. Series 1 auto dash cluster GC $30
7. Complete A/C system minus AC compressor GC Price subject to part
8. R33 washer bottle with washer motors GC $35
9. Factory series 1 intercooler GC $50
10. Series 1 power steering pump GC $80
11. Factory cross over pipe with factory BOV GC $30
12. RB25 NA block with rotating assembly minus sump, oil pump, oil pickup (from an R32 – head only used in RB30DET build) GC $100
13. Caster rods, sway bar etc GC Price subject to part
Miscellaneous
1. GFB BOV GC SOLD
2. Used Bosch 044 fuel pump GC SOLD
3. New Greddy copy intake manifold for RB25DET GC SOLD
Please note that prices DO NOT include postage.
Thanks for helping me clean out my shed.
Edited by BH_SLO32
https://www.sau.com.au/forums/topic/176788-r32-r33-gts-t-parts/
Update:
R32 dump pipe SOLD
BOV SOLD
Any pics available? And is used or brand new?
Manifold is brand new. Bought in Jan this year and only just took it out of the plastic the other day. I have bought another manifold so it is surplus to my needs.
Yes, but I don't wish to separate from the overflow bottle. Feel free to make an offer on the O/F bottle.
Cheers
Hey mate
Any chance you have a radiator overflow bottle cap? (the little yellow one)
Cheers
Edited by BH_SLO32
hey bro how much do you want for the auto shifter and
what condition is it in??
From memory it was in good nick. Will take some photos tonight. Asking $25 + postage
No, I don't have the standard vacuum lines sorry.
Cheers
Edited by BH_SLO32
Sorry but the shifter is not in the best of condition.
also do u have the standard vacuum lines going from actuator to standard
boost solenoid etc?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
