Hmm basically i dunno at to spend my tax returns on haha, heres my few ideas;
option 1: 100,000km service including
-New Timing Belt Idler & Tension units, Cam Seals & Front Main Seal
-New water pump
-Trust heavy duty timing belt
-Trust adjustable intake & exhaust cams
-Trust clear cam gear cover
(i still have to check if my car has or hasnt already had a major service with belts and stuff)
option 2: kakiregu06r.jpg this *drool*
(i do already have a cat back and full 3" dump pipe but the cat back isnt a cannon its the oval style, and its very quiet + its dinged...and i want Ti :()
option 3: A leatherette retrim (all black) and LED tail lights
option 4: a Defi Link Display so i can have all the info i need without 5 gauges all over the place, including sensors for water temp, oil temp, oil pressure and fuel pressure ( i already have a boost gauge)
option 5: HKS EVC V and a Apexi AFC NEO (wont be able to afford install and tune though haha)
__________________________________________________________________________
Option 1 would make a lot of sense if i havnt already had one, could even replace the cam gears and cover for something more usefull on the list
option 2 is somethin gi AM going to get in the future anyway, so my reasoning is i might aswell get it while i got bulk cash cos otherwise it will take me a while to save up and i could buy many little things quicker than i could get one big thing
option 3 i think would be the most stand out, people (my friends) would notice this the most, and its even something i would see every time im in the car so i would appreciate it
option 4 is something i want but i suppose it could wait, although if it should probably come before boost controller and AFC so tuners can monitor engine
option 5 is the more power now option haha, i will get round to these things if i dont buy them now, and also if the engine hasnt had the big service it would be better to do that first
but aside from those options theres more stuff i want that maybe you think would make more sense ?? heres a few :)
- oil filter relocation kit
- bosch in tank fuel pump
- HKS fuel pressure regulator (due to misunderstanding i have the adaptor and not the actual FPR so now i need to buy it anyways :))
- Ganador mirrors, just hot !
- front lip for the bumper
- aluminium radiator overflow tank
hope for some good input here :) any of your own ideas are welcome, hope fully this thread isnt too dumb haha, i just cant decide :S
cheers
https://www.sau.com.au/forums/topic/176926-how-to-spend-tax-returns/
I got a decent tax return, but need to save it for insurance next year :( Its going to kill me!
I could just blow it on some coilovers, cooler kit and EBC right now... :)
I guess for your situation i'd go on what you think is the best option as far as your servicing bits. If not, i'd be picking something that i'd get the most enjoyment out of. For me - the EVC and AFC
thanks for the input so far :D
seeing as ive found out i have had a majour service,timing belts +water pump and who knows what else already im leaning towards either a new cat back, maybe not the one pictured, not sure or the interior retrim with LED tail lights and ganador mirrors, i think i will end up going with the latter of those, seeing as its all DIY :)
...but my mind will probably sway :S
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
    • House of Fatz dry dock needs a clean sadly one of the long time stables is leaving this weekend   see ya mr purple
    • Hence why I've only modified my car into a pure daily. Everything has to remain reliable & roadworthy, while providing value and grin factor. It also must not be handcrafted to the extent that the car will be immovable if something breaks because you cannot get or make a replacement to at least limp around with.
