  • Replies 72
what brand are they?
They're 'Tai Chang Xenon' I can vouch for them as I've had a set in my car for 18 months now after the factory Phillips ones went yellow.
hey mate im in brisbane too are they cheaper if i pickup if in the area?
sorry I can't arrage any local pickup with the lights.
  • 1 month later...
Hey Dan, how do the 6000K compare in "brightness" to 4300K?
Is there much of a difference cause dosn't 4300K have the most lumens output?
Thanks.
Dave
Edited by wisey18
i always get confused with these sort of things lol, are these just normal globes or are they for xenon ballasts?
My r34 came out with xenons, but were taken out during compliance, so will these just slot straight in?
4300 technically do have the most lumen output, but considering the age of most of the R34's out there at the moment, 6000K is brighter purely for the fact it's a new globe. The other thing that happens is with my factory bulbs they went from 4300 or so to 3500 over a period of time and literally looked like tungstens :D
R34GTFOUR - You must have the ballast fitted for these to work, they're HID globes, not filament type.
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
