As we all know the dollar is so strong so I logged onto http://japanparts.com/ again and ordered a Nismo Dash (280km/h and 8000rpm in white for $650 plus freight) and some other little things, so for the guys who asked me about the clear indicators, the factory painted body kits or the 3.8 litre stroker kit the prices are that much better, well no one asked for the 3.8 stroker kit but I threw it in.
And for the Transmission Oil guys this is were I get it from so for OEM bits not listed like the oil to make life easier and a response quicker email the info below to suit your car to [email protected] and it goes direct to Graham.
DETAILS REQUIRED
Name:
Address:
Phone:
Fax:
Email:
VIN NUMBER
CHASSIS CODE
MODEL
OEM PART NUMBER IF KNOWN
PART DESCRIPTION
COMMENTS
You order it to suit the car with the VIN number if you want to be exact, CPV35 Manual or Auto, NAV System or not, they are made at time of order by Nismo and it is 3 to 6 week wait with no return if they don't work (a Nismo thing).
I fitted one to my car to make sure it worked and it was out of a CPV35 manual with NAV even though mine is 6 speed 4 door with basic Double DIN fitted, why Nismo say this I do not know.
If you order one for your VIN giving all the info I cant see a problem but it is up to you.
  • 5 months later...
Has anyone ordered the impul high power ECU from japanparts? Not sure if that's for manual only or will work with auto or not.
http://www.japanparts.com/db/category.php?...er=5&car=76
It's under ECU. You'll need to give your ECU part number so they can register it with the factory immobiliser from Nissan, otherwise probably you won't be able to start up the car. that also means that very likely people cannot trade these ECU as second hand unit because it won't work in another car.
  • 10 months later...
I have that high powered ECU in my car thats getting complied , what does it do and what good is it. I'm having a feeling the petrol here will be a problem for me.
Avgas is race engine (aircraft fuel in most cases) and comes at various specific octanes, sometimes at 110 octane (or it used to be available like that).
It smells sweet when being used and will boost most standard octane ratings, I have run it in carby jap motorcycle engines at about 30% ratio, but it was never very cheap.
Is also a bit hit and miss, but never caused any problems to me.
I am sure that you could still get it to raise the octane level of the crap Aussie fuel, however I would doubt there is really a need in a light tune V35.
You also need to be very careful that you get it right, so do a lot of research and tune on a Dyno.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
