there defiantly forgies. The piston you have are sold by precision performance. they retail for $1500. they are some chinese brand but dont be to worried there no to bad really. these are mine that we put in rb30's for a cheaper optioned rebuild. Just put it all back together and drive it, as lond as there not damaged it will be sweet. cheers
mate.. you are a legend! :)
I owe you a beer!
:D
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3244710
  • Replies 64
Those pistons are Hypatec liquid forged. They are a semi forged piston and are hypereutectic. They are sold by Precision International, they are not a bad piston though I haven't used them in any turbo engine.
More info here: http://www.precisionintl.com/HTML/product/...hypatec_lf.html
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3246111
my advice is now that you know what brand the pistons are, contact the piston manufacturer and ask them wat PTB clearance they reccomend. it may in fact be 0.1mm (unlikely, but possible).
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3247161
**UPDATE**
I WAS looking for a piston to bore clearance of .035 - .05mm (as per Manufacturers requirements)
Called up some blokes down at Silverwater and .1mm seems too big..
So..
plan of attack..
Piston size of 85.95mm WILL fit a stock RB25DET bore and have a gap of .05mm (recommended gap) - Anyone interesed in a cheap set of forgies that will fit stock Rb25DET bore?
BUT
Because the mechanics at deadshit's mechanics R US bored the block out by .05mm (and hence increased the clearance to .1mm and therefore too big) the block and piston combination will not work.. - anyone looking at a cheap 25det block?
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3248658
I doubt it has been bored out 1 thou, 2 thou piston clearnace cant be right for the forgies, its just too small, they would sieze. 4 thou is only a little loose, why not just chuck it back together, it wouldnt have been causing the massive dramas that the car has.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249566
GTS4WD,
Try not to over complicate things.
Send the block in to be bored/honed WITH the set of pistons. The machinist will measure up the pistons and bore to suite your intended application. Obviously have a little discussion with regards to what the piston manufacturer recommends, intended use etc etc.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249624
GTS4WD,
Well im looking to put together a hi comp 25/30 NA project together.. so.. dont have much use for this..
But I may get the block sleeved and sell the whole bottom end off with the pistons..
Ill get a few quotes for getting it sleeved.. but I mean.. I seen a fair few 25DeT blocks going HEAPS cheap lately.. so Im not sure if its worth it.. but I will get back with you guys about it..
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249785
Those pistons will run .05mm or so clearance. They are not your usual forged piston which is forged from a billet, they are more along the lines of pressure cast. Being hypereutectic, the coefficient of thermal expansion is a lot lower than a piston forged from a lower silicone content alloy, so not so much difference in size from cold to hot. It would be a lot cheaper to buy a set of pistons than to have the block sleeved.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3250068
    • My 3.8 kW system (when new, not so much nearly 20 yrs later) will do 21 kWh per day (best few months of the year), and that's with an afternoon shading issue. So it really could/should be able to do maybe 24. So a 6.6 kW system probably cannot fill a 40ish kWh battery from scratch, but then it is very unlikely to ever need to. Let's presume that you use 10-15 kWh during the day and stash the rest. So long as the battery isn't drawn down below ~50%, it'll be fine. And that draw down presumes using 20 kWh overnight, which is a reasonably heavy draw. So that seems reasonable. The 40kWh will be good for extended outages, and very bad days where you get almost no generation for a day or two. Might struggle to top it all the way back up after it gets pulled all the way down though. I'd think you'd probably want about 10 kW of panels to make life a little easier, wrt keeping a 40 kWh battery charged. But then....does it really need to be at 100% every day? Probably not.
    • Am I wrong in thinking that there is a hell of a lot of battery storage for a 6.6 feed into it Your battery is around 4 times bigger than the battery that is going into my place in a week, but I have nearly twice the feed Will the batteries actually ever get fully charged? School me on the science bitches
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
