Hey Guys,
Just wanna see if anyone is up for this weekend on sunday, given more notice this time. Jus say if ur up for it and ur name will go on the list. We will be meeting up at forrest glen BP next to the Grammar School - Left hand side heading towards Ettomogah Pub at 11am, cruising from there to montville or mapelton for some lunch and we can check out all the other cars, get to know some of our SAU buddies better :rofl: hope to see u guys there. give us a shout and ill add you to the list :)
Cheers.
People Going:
Darkness_ryda1
Sunnycoast
Redsenigma
R33cruiser
Kobe 2007
and others haha :blink:
Edited by Darkness_Ryda1
https://www.sau.com.au/forums/topic/177346-bring-out-your-babys-for-a-cruise/
New date posted
ill be there if my car is done in time, it should be out of the panel beaters by friday if there are no delays. then must install dvd player, if all goes to plan i will be ther.
I think a lot of the regulars are on SAUQLD.com members forum. I would have turned up to this had i seen the post in time.
yea, it was posted up a week in advance, have to check the events section more often :yes: alot of people dont.
Cheers
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
