  • Replies 843
Posted Images
quickest 'street' car was Mark Hayes LC - 8.3 and quickest jap 'street' car was Rigoli ute - 7.9?
8.3 > 7.9 ???
I'm confuzzled????
Sorry, didn't read street in your post. I think the Galant - 11.something
dont be like that, it was a shake-down meeting and it was well worth it by the sounds of it. although the ET were dissapointing the MPH is encouraging. Its not easy to get a boat to run 11s. I guess you found that the transbrake is a no-no on radials with current suspension set-up. but wont say i told you so.
Its time for 30 psi and the bottle back...... :)
Fixed. :)
Its time for 30 psi and the bottle back...... ;)
I said at the start of the day that with the current tune-up, an 11.xxx would be a success. Job done. Now it's time for 30psi. Bottle later.
yes the boost will definately help but unfortunately the car will never sixty without the bottle.
i though you were building your car to run in a street tyre bracket where you could be somewhat competative, ie no transbrake and radial tyre. you put a slick on that car and you will brake every component in the rear end and be at least 3 seconds slower than your field. i think you may have lost your way somewhat........ :) car ran quiker with standard turbo and manual box on a street tyre.
how much quiker do you think its going to go?
What do you think the transbrake is for? Shopping for real tyres now.
1/ The class you're referring to now allows transbrakes and slick tyres. See www.sportcompact.net.au for details. What's more, they now only run 2 events per year. Not worth building a car solely for that many events.
2/ Slicks will be softer on the drivetrain than radials and you know it.
3/ The car is within hundredths of a second of its PB on its very first meeting out and with a 2.00-sec sixty instead of a 1.6. You do the math and tell me how much quicker it will go by just getting it off the line that quickly.
you dont need to put a slick tyre under that car dude...that would be wrong!
yes the sidewall of the slick will soften the initial shock loading but the lack of tyre slip will see you turning driveline components instead of tyres.
you are a street dragger and reasonably good at it...fu(k Ray Box's stupid new rules..race Andra Super Street and get the car running 11.0 all day. Thats the best option for you that i can see.
At least with Andra you will get a proper track instead of the debacle at last years Compak. The track was a 330' strip as clearly the rest of the track was unprepped. Watch all of Marks vids...the car was 330'ing quicker than its ever gone and then sideways for the rest of the track after he passes the 330 timing boxes.
Edited by DiRTgarage
I love racing on street tyres and the Street Car Superstars event was great but I've always said I'll stick some slicks under it and see what it can do and I reckon it's up to me when I do that. Just a thought.
Isn't the car bogging off the line now? I cannot overpower the tyres in my car on radials...mind you i have twice the grip but also double the power. Why don't you run the car as hard as you can first on the SDR's then maybe think about slicks. You can do what you like with your car honestly i couldn't care if you put wheels on its roof and drove it upside down. Just a thought.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
