HICAS only kicks in when the car is travelling over 80km/h, rear wheels turn 1 full degree and you can feel the car 'kick' alittle. Thats only if you are turing a large bend around a highway or blasting it through a corner.
If you check the powersteering fluids front and back, check the fuse as I have mentioned in other threads
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3644272
its that going effect my car lyk handling?wot u reccomend to fix it?
you should be right, i dont think the hicas will activate if its in error mode. being a 33 its all electric so nothing to do with fluids. you could check the fuses, easiest thing to do.
if they are all ok and you still have the stock steering wheel put it back on and see if you still have the problem. if it goes away then i'd look for a boss kit that is hicas compatible, i remember a thred out there where everyone was listing the boss kits they used and that were compatible.
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3644285
Lockbar. For (as stated earlier) between $30 and $300 you can have a lockbar. Your HICAS light will stay on, but no more weird arse feeling in the back end :)
HICAS operates at speeds heaps lower than 80kph..... Fang it around a roundabout and you will feel it... The angle of (rear)steer depends on what speed you are doing at the time... Ie. If you are dawdling around a carpark, you will NEVER feel HICAS operating.... It will however operate above 30-40kph. At lower speeds the rear wheels turn in to aid steering and at higher speeds they travel in the same direction as the front wheels(depending on how much lock is wound onto the front wheels).
When drifting with HICAS you can really feel the rear wheels trying to straighten you out of the slide. It also gives you a really false sense of where the car is actually pointing...
On my mates skyline when hicas come on the sterring gose all stif. What dose that mean? :banana:
Low fluid if it is pre Super HICAS
https://www.sau.com.au/forums/topic/177506-hicas/page/2/#findComment-3669191
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
