MissSky Posted July 22, 2007 Share Posted July 22, 2007 Hi, I need some help. I have a Rb20de in my Skyline. One of my injectors has cracked and I replaced it ever since then it feels like the car is running on 5 cylinders. Please help as I dont want my car to die!!!! Link to comment https://www.sau.com.au/forums/topic/177684-please-help/ Share on other sites More sharing options...
NISZILA Posted July 23, 2007 Share Posted July 23, 2007 Try reseting the ecu... may do nothing, but its easy to do. It will make the car start learning its fuel mixtures etc again. Do this by diconnecting the battery and then get in the car and turn all the lights on, your foot on the brake etc. This will drain the remaining charge in the system. Do this for about 5-10 min. Try pressing your horn. If it does nothing, your discharged. If it makes a sounds keep going a little longer Once you've done that, reconnect the battery and test it out. Link to comment https://www.sau.com.au/forums/topic/177684-please-help/#findComment-3244026 Share on other sites More sharing options...
MissSky Posted July 23, 2007 Author Share Posted July 23, 2007 Try reseting the ecu... may do nothing, but its easy to do. It will make the car start learning its fuel mistures etc again.Do this by diconnecting the battery and then get in the car and turn all the lights on, your foot on the brake etc. This will drain the remaining charge in the system. Do this for about 5-10 min. Try pressing your horn. If it does nothing, your discharged. If it makes a sounds keep going a little longer Once you've done that, reconnect the battery and test it out. thank you I will give it a go and hopefully that works Link to comment https://www.sau.com.au/forums/topic/177684-please-help/#findComment-3244032 Share on other sites More sharing options...
NISZILA Posted July 23, 2007 Share Posted July 23, 2007 Thats cool Let us know how you go Link to comment https://www.sau.com.au/forums/topic/177684-please-help/#findComment-3244234 Share on other sites More sharing options...
