  • Replies 433
Posted Images
I'm after a front and rear set of QFM A1M or K750 pads for a S14 :thumbsup:
Front pads are the same as R32 GTS-T, Z32 etc...
Do you accept Credit card or Pay pal?
Let me know asap! I need these before June 9th!
I'm after a front and rear set of QFM A1M or K750 pads for a S14 :teehee:
PM Sent :geek:
Is there a chance of getting a price (if available) on the K500 front and rear pads for an R33 GTR with brembos
The k500's (and k750's) aren't made for Brembo's unfortunately. What you'd need to do is contact QFM directly, and organise for your backing plates to be sent up there so they can be re-bonded.
hi mark,
can i order a set of braided brake lines to suit '94 R32 GTR vspec II (with brembo)?
i really want to get the K750 brake pads (front + rear) as well, is there no other way of just buying them instead of sending your backing plates up? only reason is that my car arrives next month and i dont think that would be a possibility for me anyway. if not thats cool!
oh and let me know the payment options
cheers :D
Hey Mark,
You have $110.00 for stagea front lines delivered, do the stagea ones look like the ones in your pic.
Cheers,
Ryan
Hi Ryan,
Sorry for the late reply.
Yes the stagea lines look like the ones in the pic. The fittings might just be slightly different.
Cheers
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
