Okay, my heart is bleeding putting this for sale as it has been my project over the past 5 years, but family has become bigger priority nowadays!
Project is 95% complete but just needs couple more things to complete the package
R33 GTS sedan, car has about 160-000km! However, engine swap and transmission change occured three years ago. Since then the engine cracked a piston and has been rebuilt with new bearings, 40thou oversize arias forged pistons. The engine has done only 25000km since rebuild. Gearbox was also stripped down and had all synchros replaced at the same time. The rebuild was done in november 2005, the car has spent the last twelve months off the road as it was getting painted and took a long long time to get back together again. Original colour was silver two tone but now is coated in Ford Velocity Blue with a percentage of prismatique blue (sparkles) being added in as well.
The baby comes with;
Series 2 RB25DET bored 40thou, Arias forged pistons. Engine runs series 1 wiring loom (Last time tuned made 205.4rwkw)
Recently Rebuilt Gearbox 5 speed
Recently rebuilt tail shaft, replacing all bearings and yokes
Kaaz Mechanical 2way LSD
PWR front mount cooler 600\300\60
Modified Inlet Plenum (polished)
Brand new Alloy Radiator
Series 2 turbo with 3" exhaust, Turbo back
Bosch 044 fuel pump
Eboost electronic boost controller
Wolf3d version 4plus ECU with hand controller
GTR dash
Painted interior (dash etc)
Bilstein suspension
TV, pioneer head unit and two amps
10" pioneer sub, pioneer front splits and pioneer 6 by 9's
This is a absolute gorgeous car. Has done no more then 100km since respray. Things that still need to be done to the car are as follows:
New seals around front rear windscreens
Clutch thrust bearing noisy and may need need to be replaced soon
Brake upgrade as to allow car to be engineered legally
Car is registered until 20 DEC 07
$14000
https://www.sau.com.au/forums/topic/177826-r33-gts-sedan-1994-rb25-det/
so it was a non turbo to start with, was it auto as well?
and has the inlet plenum been flow tested or is it just a backyard job of modifying trottle body position
makes me want to get rid on my 4dr 32 with the rb25 in it. wish i had the money to come and get it. looks rather tidy. why the brake upgrade?
gl with the sale
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
