I know this is a Skyline forum but this should be something of interest to you guys.
Turbo AWD AUDIs are quite popular modified cars in the U.S. and Europe. Here we have an U.S. company whos developing an GT2871 turbo kit for the lastest B7 AUDI A4. http://forums.motivemag.com/zerothread?id=3277677
235kw at all wheels from a stock internal 2.0 litre direct injection 4. Not too shabby don't you think?
Edited by BaysideBlue
https://www.sau.com.au/forums/topic/177969-garrett-gt28-71r-on-an-20l-audi/
Very impressive looking graphs, possibly a little high-end biased for the torque curve. Table-flat from 4800-6300 is a great achievement.
Given what is on the original thread, I'd like to see the results from a GT28RS for an earlier serving of torque down in the mid 3000s.
Depending on the mass of one of those Audis it should still be quite lively though.
