APEXi POWER FC's with FC Commander for R33 GTS-t and R34 GT-T BRAND NEW IN BOX, MANUFACTURER BACKED WARRANTY AND SUPPORT.
VERY LIMITED STOCK NOT AVAILABLE IN JAPAN, PRICE VALID UNTIL THE END OF JULY!!!
$1540!
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 months later...
Hey mate,
pm me if you have any more r33 pfcs left, or if you are getting some in stock soon
cheers
They are currently an order in item approx 6 weeks upon payment
Gday mate, just wondering is it the same story with the R34 GTT fc's....order in and 6 week wait? and is the price still $1540?
Hi I currently have them on shelf
Ok this might be a really stupid question, but is there any way i can put a deposit on one and pay it off?? i dont have the 1500 to spare at the moment, but am super keen on getting one and really dont want stock to run out....
  • 3 weeks later...
any power fc's d jetro for a r33 gtr?
  • 4 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
