Hi all.
For those of you who have competed in Targa Tasmania, what was involved in preparing your car?
I'm investigating competing in Targa Tassie 08 in the rookie rallye section and just need to work out the costs of preparing my current road going car.
I guess i need a half roll cage, driver+navigator harnesses, toe hooks front and rear.........
Any info would be great.
ap
https://www.sau.com.au/forums/topic/178133-targa-tasmania-question/
Ok well if you go to the targa page, there is a requirament list.
We competed in Targa Rookie Classic Class C.
We needed:
Fire extuinguisher
Battery cut out
Fuel Cut out if fitted with electronic pumps
Role cage, Cams approved with papers, seamless tube, all bent and wealded as per the rules
Fire suits, gloves and face mask, ADR approved helmett.
You need a first aid kit
Triangle for breakdowns
Tow points in red, indicated with a sticker
These are the main have toos
Then thre is a whole heap more, like battery triangle stickers, they give you those, tiedowns for any loos items, Terra trip is not required at all. MAKE SURE You have good pace notes, we didn't and crashed. LOL.
Your car needs to be registered and road legel, well roar registered under special interest at least, so all lights must be functioning ect.
Edited by WogsRus
You need a minimum of a 5 point harness (and remeber to have it realy tight, or your balls get mashed), there's rumers going around that bolt in cages mightn't be accepted soon, but that is only a rumer. But if you do it, put a weld-in in, it's worth it if you do crash.
how many mods does your car have? because the cars are mostly standard parts.
The targa site has all the regs up, and a link to the cams technical regs.
What you need more than anything...is a car you can thrash for 3 days without it breaking down in any way....so have a think about what sort of condition everything is in and what you might need to replace. Like Ben said it has to be pretty much standard too so you might have to remove bits you already have.
Cage is probably the hardest thing - you can get a bolt in one so you can remove it, but it needs to be a full cams compliant one - think $1500min.
Was your wedding photo in the paper the other day Stu?? It was a Stuart Benson and looked a bit like you....but it might've been a funny angle and I wasn't sure.......
Yes mate that was me, obviously Kylie is a very lucky girl!
The photographer wanted to use that shot for promo and I wondered where it was going to show up.
grr we ordered and paid for a party dvd at the same time we ordered the offical one.....neither has arrived yet - I know the offical one is delayed but its really the party tape should be here by now :)
grr we ordered and paid for a party dvd at the same time we ordered the offical one.....neither has arrived yet - I know the offical one is delayed but its really the party tape should be here by now :D
ummmm did I forget to tell you I told the guys to send the DVDs together.... :P
sav_man - Yeah I think we've still got some, will check.
Duncan& Kel - They will both be worth the wait!
The DVD would have been released sooner as dat16 and the SCTV team finished them some time ago, but they all arrived back from production with the wrong covers and these had to be printed.
In regards to the party DVD's I have located the source here at work and can supply copys at the nominal fee of Twenty dollars.....
We can also do packages that include all shots of you'r vehicle compiled, along with a personalised party tape version that has shots of you'r vehicle inserted into it....
Obviously there is more cost involved in the vehicle compile's and party tape inserts. Those that may be interested will need to contact me for details... I personaly have done many compiles and they can take anywhere from 1/2 an hour to 2 hours depending on how many shots you have to locate.....I think there is somewhere in the vicinity of 70 to 80 tapes from this year!!!!!! :action-smiley-069::(
I am at you'r service.......
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
