Carmate.com
Hi All,
Just bought a R33 flush boot lid and GTR grill from the above mentioned Carmate and my panel beater's quote went from $200 spray and fit to $600 spray and fit, he was under the opinion that the boot arrived really uneven and that it would require lots of work, it seems to me though that his secound quote is a little high, Anyone else bought from Carmate and have they had similar troubles??? does the panel beaters pricing sound expensive or is that normal????
thanks for your input fellas.
this is the boot lid:
http://www.carmate.com/product_details.php...T&p_id=9411
Edited by immortal^
yeah man, there are a few posts in here if you do a search
I've bought a grille off them, total rip off paid $200, didn't look anything like the photo!!!!
the photo was plastic and with mesh in behind, i got some fibreglass piece of crap that didn't fit at all :P
i don't recommend them at all, infact I think there should be a sticky put up on this forum somewhere, maybe under Traders, saying not to buy from them!!!
There crap! they dont fit !
I use to run a panel shop and people used to try and get me to fit there body kit, can spend up to 8-10hours getting a front bar to fit somtimes.
i brought a front bar off them, it wasnt shipped the best but it arrived ok! it fitted ok but i did it my self. and got a friend to spray it for me. but it could have been better!!
Carmate are shit... there panels dont fit properly and requires a lot of work to get them to a reasoanble state. The spray job seems expensive. Give Xclusive colours in granville a call they're really good.
i bought a bonnet for my lancer a few years back and yeah it didnt fit properly but with some modifications it turned out pretty well visually apart from the fact you basically had to sit on it in order for it to clip in, taking my experience into account id always pay extra now for a better product, well worth it in the long run
bought a front bar off em arrived in like 2 days after ordering it. but there was a chunk missing out of it. but was sorted out and wasnt too much trouble with fitting. also with there body kits they are just primed not gel coated.
EEIIK!!!! what have i done ..... dam it, i guess you live and learn huh?! oh well next time I'll be sure to ask you good people first,
thanks for all the responses. :)
 Share
    • Thanks to @V35_Paul there is an oem stereo available on gumtree, but the fascia is slightly different. It has a flip up screen as opposed to my pop up screen. Am I able to disconnect the radio/cd player from the fascia to use it on mine?
    • Had to google what a quart is lol.. so rough as guts a litre. That's a bit excessive, also what oil weight are you running? The whole steam cleaning idea isn't too far fetched either. Maybe as you suggested, turn off the WMI (assuming your Kebabtech pulls timing, boost, etc.) and run it for a bit and see if there are any noticeable changes in spark plug colouring.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
