SOLD $1300
For Sale - Nissan Skyline R33 GTR wheels. I have a set of 4 for sale.
The wheels are made by BBS, they are a forged alloy wheel, not a cheap cast item.
Condition - These wheels look the same as when they were made, they have no marks on them, no scratches in the paint, no buckles, or even marks from where weights have been fitted. Hopefully the photos can show potential buyers the immacualte condition.
Size - 17 x 9 inches
Offset - +30
Stud pattern - 5 x 114.3
Not attached in photos, but these wheels do come with Genuine centre caps, will also provide chromed valves.
post-34017-1185445942_thumb.jpgpost-34017-1185445969_thumb.jpgpost-34017-1185445997_thumb.jpgpost-34017-1185446051_thumb.jpg
post-34017-1185446104_thumb.jpgpost-34017-1185446126_thumb.jpg post-34017-1185446175_thumb.jpgpost-34017-1185446197_thumb.jpg
Please note the condition of the whole wheel, not just the face - stud holes, inside edges, outside edges.
These wheels fit almost all RWD Japanese cars and 4WD Nissans. They are the perfect upgrade for GTR, GTS-T, Silvia, S14, S14, R34 GTT, and many others.
Weight - Without tyres I have found each wheel to be 10kg.
Location - Sydney, Thornleigh area (2120). Sorry, no interstate sales, must meet in person.
Price - $1400
Contact details - Please reply to the thread, or send me a PM. I will reply usually within 1 or 2 days. I will give my mobile number to interested buyers.
At the moment no tyres are included in the sale, but I am trying to obtain some brand new 235/45/17 Pirelli Pzero tyres. These will be included but at a increased price rate (still cheaper than retail).
Adrian
Edited by Sticky
https://www.sau.com.au/forums/topic/178217-r33-gtr-skyline-wheels/
Well, it depends on how much the tyres cost me. My mates dad works for Pirelli in the Motorsport division and is fairly high up.
So hopefully I should be able to get the brand new tyres for about $200 for all 4... and I will only add whatever the tyres cost me to the price.
Retail they are like $300 each, So they will be a bargain.
Adrian
Anyone for a kidney?
I need to sell some rims, and FLY4DR needs to sell a kidney.
The photos dont really do the wheels justice, they look even better in real life.
DAMN if u can get sum new rubber that price ill buy some of yah
As much as I would love to get people tyres at that price... I can't.
But if you want cheap rubber and don't want the wheels, it may be worth your while to buy the wheels with the tyres when I get them, then resell the wheels at a cheaper price than I'm asking.
Ronin 09 - No these wheels haven't been repainted... But yes they have been powder coated, they were in perfect condition before but they weren't silver...
They should stay in this condition for many years to come. Done properly - Acid cleaned before powder coating.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
