what you need to get into your head is that the requirements for a drift car and a drag car are completely different from a power delivery and chassis set-up point of view
trying to build a 'hybrid' to do both jobs will result in a car that is compromised for both diciplines
to just 'turn the boost down' at the drift track won't help with regard to response- what you need for drift would be to use a turbo that will be able to make around 500hp with the smallest exhaust turbine size possible (somewhere around the .6 A/R range)
you'll notice in your video that even at freeway speeds, and changing at redline, the 3L R34 still had a brief pause after gear changes- this wouldn't be great on the drift track
  • Replies 67
okay i think i'll just have the car as a drag car and for burnout comps
i got a rb25de non vct head.....but i'm selling it on ebay now
i could have built another motor rb30det for drift
but whats the most rwkw from the hks t04z?
if i were u i woiuld keep the s13 an sr20 put an s15 turbo on it get about 200rwkw and drift that.
and with all the money u reckon ur gonna spend on this rb26/30 conversion get a gtr 32 and build that into ur street drag car.
and do heaps of research i reckon'
btw how old are u?????
u sound like my 9yo cousin the way u speak.
22 2day
Happy Birthday!
You say you wanna drift in a 400rwkw car, do you know how to drift by any chance or are you planning on practicing in this car? Because if you're learning in this car chances are you're gonna....... BAM!! $30k+ GONE!! sort of...
yeah thanks
i was trying to learn in the s13 silvia but it has a open wheel diff and ca18de has no power
will be getting a 2 way nismo diff and 5 stud conversion soon
any one watch that youtube lean to drift by the drift king... some one translates it to english
you know d guy he wears gloves cozz hes 2 good
i will learn b4 d motor is in coz i dun wanna wreck nuthin
im getting my tein super drift coilovers this week
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
