what you need to get into your head is that the requirements for a drift car and a drag car are completely different from a power delivery and chassis set-up point of view
trying to build a 'hybrid' to do both jobs will result in a car that is compromised for both diciplines
to just 'turn the boost down' at the drift track won't help with regard to response- what you need for drift would be to use a turbo that will be able to make around 500hp with the smallest exhaust turbine size possible (somewhere around the .6 A/R range)
you'll notice in your video that even at freeway speeds, and changing at redline, the 3L R34 still had a brief pause after gear changes- this wouldn't be great on the drift track
  • Replies 67
okay i think i'll just have the car as a drag car and for burnout comps
i got a rb25de non vct head.....but i'm selling it on ebay now
i could have built another motor rb30det for drift
but whats the most rwkw from the hks t04z?
if i were u i woiuld keep the s13 an sr20 put an s15 turbo on it get about 200rwkw and drift that.
and with all the money u reckon ur gonna spend on this rb26/30 conversion get a gtr 32 and build that into ur street drag car.
and do heaps of research i reckon'
btw how old are u?????
u sound like my 9yo cousin the way u speak.
22 2day
Happy Birthday!
You say you wanna drift in a 400rwkw car, do you know how to drift by any chance or are you planning on practicing in this car? Because if you're learning in this car chances are you're gonna....... BAM!! $30k+ GONE!! sort of...
yeah thanks
i was trying to learn in the s13 silvia but it has a open wheel diff and ca18de has no power
will be getting a 2 way nismo diff and 5 stud conversion soon
any one watch that youtube lean to drift by the drift king... some one translates it to english
you know d guy he wears gloves cozz hes 2 good
i will learn b4 d motor is in coz i dun wanna wreck nuthin
im getting my tein super drift coilovers this week
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
