Hey guys am in the process of converting my dr30 from fj20 to rb25, i am in 2 minds to whether i can actualy be bothered mucking around with the power steering stuff as they are on apposing sides, Just wanted to know how do people with no power steering, steering boxs go? are they massivly heavy to drive and control (I only use mine on the track)
I had and rb20 r31 and the belt slipped off once and farking hell its was night mare to drive, will the r30 be the same?
cheers josh
https://www.sau.com.au/forums/topic/178523-dr30-power-steering/
with the extra weight of the RB it will be quite heavy un-assisted. but as it's a track only car you could try to find a quick-rack non-power rack. but...still be a tad heavy. go to a rally/motorkhana/sprint meet and ask the owners of said cars and ask them what they did, is it better..did they find a compromise...etc.. good luck.!
good luck with the conversion josh!
ive driven a non-power steer R30 with a RB30 in it... was ok in a straight line... but it was a BITCH in corners and parking, getting onto a trailer etc.
i suggetst goeetin some custom lines made by ENZED or similar... its well worth it.
cheers,
Andrew
mines a 1982 HR30 non powersteering model and its not that heavy in the steering department and i have an rb20det in there so won't be to different to the rb25det i'd say?
i also think you'll find its just the power steering pump thats on the other side and that the lines connect about the same place as the r31. maybe look an getting custom lines made if you want to keep the PS or use an r31 pump and lines??
Edited by rsx84
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
