For sale:
Garrett GT30 turbocharger $1100
*SOLD*
Part number: XTRGTSB005A (AKA 3037R)
(rated @ 450hp by GCG)
Compressor: 2.17/3.00 .7AR housing
Turbine: 2.11/2.22 .63 int gate housing (RB25)
This turbo is a garrett GT30 fitted with an internal gate exhaust housing from a RB25 by GCG and the internal gate has been bored out and a larger hat has been fitted for more wastegate flow by ATS in Adelaide.
I have used the turbo for 1100km’s on a Gemini (G180) and the previous owner claimed 2000km’s of use on a RB30 so the turbo is still fresh and shows no signs of wear on the compressor or freeplay in the shaft.
The RB25 exhaust housing makes this an easy upgrade for any RB25 or RB20 powered car and it also features a polished compressor cover. I previously had a HKS2540R on my car and this turbo is alot more responsive and only made 16rwkw less with 2 psi less boost.
I am located in Adelaide but am willing to post interstate at buyers expense.
PM or e-mail me if you are interested or have any further questions.
Cheers
*SOLD*
0408842125
or
[email protected]
the turbo will be sold not with the HKS actuator or water and oil lines as pictured but it will have a new garrett actuator off my new turbo.
Edited by S3_Girl
https://www.sau.com.au/forums/topic/179056-fs-gt30-turbocharger-sold/
Johnbarry88- Nah sorry mate need the cash to put a bigger turbo on.
Salad- It made 180rwkw on 19psi on my G180 (1800cc SOHC) but i have since discovered my cam was an atmo grind and was harming the response and power production, to what extent i will never know now. Cant remember what results the guy i bought it from had but i am pretty sure he was from this forum.
Pauly33GTS-t- I guess you are running an RB25 how much power does it make and when does it hit full boost?
Fordy- was that vip-r31 or vip_r31? cheers
Edited by S3_Girl
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
