Hi Guys, my first posting for skylines australia >_< i know this topic has flown around these fourums and many others for ages but i need some help. I have just picked myself up a 260RS which i have been paining to get for atleast 4 years and through that whole time all i could ever imagin on it was R34 GTR rims. So thats what im going to do... but there is so much gab going around that they won't fit, you can make em fit some say, u'll never get em in there others say, you need spacers and long wheel nuts...
Has anyone done the fitout and acutally got it to ride well and perform well?? if so what mods need to happen? any help would be appreciated. Thanks all
~PW~
https://www.sau.com.au/forums/topic/179064-r34-gtr-rims-260rs/
They fit no worries. check out my gallery if you want to see what they look like when on. darrinspencer also has them on his. my rear wheels are a very tight squeeze, but darrinspencers are ok, but I think that's due to my conversion, so you should have no probs.
Congrats on the car!
Wicked guys thanks heaps, i have seen plenty of them on the RS4s but was under the impression that the autech hubs and such were different... are the gtr rims 245s Rear and 235s fronts? theres nothing worse than having your brand new machine sitting outside ur office window while you work it just begging to be driven :(
do you guys have any ideas of cost for the rims? i have seen all sorts of different pricing around what do you thinks reasonable? if i need to get the guards rolled whats the best way? one of those "so easy your girlfriend could do it jobs? or is there a better (still cheapish) option?
Thanks people
while we are on this subject.. ( and sorry for the hijack ) but ..
I noticed with our car.. its got the autech rims on .. and you can see the track of the rear is wider than the track of the front.. and the rims have stickers on them stating the rears are for rear use only and the fronts for front use only.. so if you have directional tyres.. wheel rotation ( to ensure even wear ) is out of the question!!
Have a search thru the for sale section. Has been a few sets lately for sale
Sell price is approx $2000-2500 for a good set with no gutter rash and no tyres
Rim size is 18x9 30+ offset front and rear.
You can run any tyre from 235 to 265 wide on 9 inch rims, but 245's fit best on the stagea
To roll rear guards, take the car to a wheel shop. They have a machine that does it for approx $50 per corner
But you should not have to do it unless you put the wider tyres on.
Yes
The autech rims have a different offset front to rear
I think from memory fronts are 30+ and the rears are 20+
So that means the rear's will sit a further 10mm out each side
Wheels are 17x8 I think
Have a look on the centre of your rims, the offsets are cast on there
You will have to get tyres taken off the left hand rims and put on the right hand rims to rotate them
Fairly typical too when you have wider rims/tyres on the rear of a RWD car
Great mate thanks for the Input! ill try and snap them fellas up straight away, ill let everyone know how the fitment goes when i get them. I have the alarm install next week and will be fitting all my audio gear the week after.
Alpine deck
Alpine type-R Sub
Alpine 4chn Amp
Alpine Mono
Boston Pro 6.5 splits
Boston midbase Pros
Can't wait!
Alpine deck
Alpine type-R Sub
Alpine 4chn Amp
Alpine Mono
Boston midbase Pros
Can't wait!
Sounds nice!
I've got an Alpine deck running Boston splits in the front doors, with matching Boston co-axials in the rear doors, and will be getting a sub and amp once funds allow (most probably Rockford for both).
Yeah should be wicked, how did you go getting your tweeters in the A pillars??
Mine came with factory tweeters in the a-pillars, so I just removed them, ran new wires, and put the Boston ones in place of the old ones.
Yeah mine has the factory locations was just wondering how difficult it was to get all that removed... i think when i do the speakers in the doors im going to pull off both mirrors and check for rust... seems to be a common thing, i don't really want my doors rotting off.
A little off subject but is there a Stagea Audio install thread on here?? If not i might fire one up
GTR rims are 18x9 +30 and no rubbing? What tyres are you running?
Grant seemed to think that a 18x9 +15 was going to be a big issue.. Sounds like a crock to me >_< :laughing-smiley-014:
235 40?.....45? I think I've got 235 45's on mine: the tyres have that really stretched thing going on, because the rear rims are very borderline as to wheter they sit outside the guards or not. I'll check when I'm back in Qld again: mid-week. I even managed to get them engineered, as Qld law states thet the tyre must sit in he guards: they never said anything about the rim..... For the record, they do scrape with 4 people on board, but only a little, and I'm running SK's suspension package...
I'll get back to you about tyre size in the week....
i have an 18x9 +20 with lots of camber and a huge roll
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
