19th August 2007, Brindabella/tidbinbilla Cruise
ACT MR2 Club invites Skylines to our monthly Brindabella hairpin cruise.
It's a short cruise. It will take about 2~3 hours, including meet & greet, hair pin drive and coffee/snack at the Tidbinbilla tracking station. It's a nice little drive.
- Meet at 10:30am, at the National Museum Carpark, Acton.
- Destination is Tidbinbilla tracking station via long way, through Uriarra Rd.
Bring your car, fuel, CB radio if have one (ch 14) and some cash for coffee & snack.
Friends are welcome. But, note that girlfriends & wives usually find this event really boring unless they are driving.
We are car enthusiasts like you & I - sociable, friendly people. Any anti-social behaviour and egoism are not welcome.
We tend to keep our speed at the speed limit. We don't encourage people to be hoons. It's under your discretion, it's your reponsibility.
- Do not attempt any illegal, dangerous maneuvers.
- Drive at your pace, don't be pressured to show off.
  • Replies 42
We have more Skylines than MR2s coming at the moment... :sleep:
Skylines:
- Zenith13
- Glenieboy
- Darkon
- Darkon's mate
- CeJay
- Terminal
- Mang (maybe)
- LadyBytes (maybe)
- Frink (maybe)
- RB20tR32 (maybe)
- Baconer (maybe)
Edited by zenith13
Skylines, Roll call update:
- Zenith13
- Glenieboy
- Darkon
- Darkon's mate
- CeJay
- Terminal
- Mang (maybe)
- LadyBytes (maybe)
- Frink (maybe)
- RB20tR32 (maybe)
- Baconer (maybe)
Yep. I'm still in
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
