  • Replies 100
If you guys can get a few cruises and what not happening, I'll look into get CAMS public liability insurance to cover you in case anything goes wrong. :)
At this stage, cover only applies to members. At least, that's my understanding of it.
  • 1 month later...
Anyone want do do the following install on my 32 GTR for free?<br /><br />HKS GTSS Turbos<br />Tomei Poncams<br />Tomei exhaust manifold<br />HKS Dumps, front pipe, Hi Power Silent exhaust<br />HKS Fuel pump, 700cc Sard injectors<br />Z32 AFMs<br />PowerFC<br /><br />I really don't want to pay 5K(quoted) to get it done professionally.<br />Ok. I'll give you twenty bucks and a high five...
Who quoted you 5k for that?
I figured it would be a day to do the turbo's and exhaust and mafs. A day to do the cams, fuel system and computers and to get a base map in it. And then about 2-3 hours tune time. I'd figure $2500-3K.
If 1/2 your parts are second hand though, there is a lot of stuffing around with fiddly extra's. Cleaning everything, sourcing exhaust studs and gaskets etc. Old R32's tend to often have broken exhaust studs that need extraction. The coolant pipes can sometimes need replacing too as they tend to corrode in and can snap off wen being unbolted. If they do come apart intact, all the pipe work should be zinc plated again to provide some corrosion protection. BCR can do this in Cairns.
  • 1 month later...
Spotted a clean midnight purple R32 GTS-T tonight on Mulgrave road in front of Mcdonalds. Black rims. It was on Gumtree but has recently been taken down. Anyone know the owner? I'd like to tee up a meet in a couple of weeks here in Cairns (When my car gets out of the shop). Interested?
  • 11 months later...
hey gents.
little heads up, ill be moving up to tolga from melbourne first week in may. got a lot of experience with skylines and what not so if you need any work done alot cheaper than local mechanics give me a shout.
also do alot of subaru related stuff aswell.
  • 2 months later...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
