HAVE ADDED SOME MORE PHOTOS.
Hi Everyone.
Think I should probably sell SHY 32. Have only done 1200 kilometers in 2 1/2 years and I am going to be busy for a while yet. It deserves a home with someone who will use it.
It hasnt even been on a Dyno since the rebuild by Jakes Performance in January last year. In fact hardly driven since the rebuild.
Some of you will know the car well. Factory special order metallic Dark Blue with White Nismo 400 18 x 10 Wheels & Blue/Grey Bride seats make it very unusual.
BIG HKS Drag intercooler, BIG single T04 on HKS stainless Manifold, Apexi Computer, no AF Meters and every option you can think of from the Japanese Modification catalogues.
We discovered a highly modified head and Tomei Cams when we opened it up. Jake fitted new Forged Pistons and Billet Rods, new N1 Water Pump and and N1 Oil Pump with the JUN crank adaptor. Head was serviced and new guides fitted at the same time.
No Dyno records since the rebuild but should be in excess of 400kw depending on how far you want to push the boost.
Has an OS Giken triple plate clutch, and supposed to have OS Giken Gear Set but we dont know for sure.
Tein adjustable suspension including Track and Camber Rods. Almost new Falken tyres.
The car was professionally built by START Garage in Japan. It is in very good condition and has orginal Japanese Service stickers indicating it has been serviced every 1000 klms.
Would really like to keep it and wont give it away, but if anyone wants to give it a good home we can discuss a reasonable price. Would consider offers over $25K I guess. The engine rebuild cost $10K+.
Wayne
Edited by Mrshy32
https://www.sau.com.au/forums/topic/179168-think-i-should-sell-shy-32/
It normally has a K&N Airfilter in a modified Commodore Airbox.
The photos with no airfilter were taken at The Summer Nats in 2006.
It has never been driven without an airfilter.
Wayne
you run a $10K engine rebuild with no air filter? :)
DAD your a looser, NAH jokes.
The car is BEAST and if I had the money it would be sitting in my garage.
Someone will get one of the cleanest, standard looking, perfectly modified R32 GTR's in the WORLD
Dan
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
