Purchased a while ago & never used. Has been peacefully resting in a box wrapped in an oily plastic bag. Turbo unit is absolutely spanking new, as are the gaskets - many of the required fittings going with it aren't new and were sourced from a used GT2530 as per the photos.
Please read the following carefully before you post your questions, guys!
This unit will bolt onto GTS-t and GTS25t manifold and exhaust. The airflow inlet is also direct fit. You will require custom oil feed line, oil drain tube, and replacement water feed lines. Alternatively the existing water feed bundy tubes can be modified by hydraulic specialists (Pirtek, Enzed etc) for minimal cost. I can provide a wastegate actuator if you wish from an R32 GTS-t. The water feed couplings for the turbo are included as per the photos.
If you'd like to know how this turbo will perform, please locate and familiarize yourself with the "search" button located directly above and to the right of this post. >_< typical results are 240-250rwKw with supporting mods, with a broad spread of torque and usable power, whilst retaining good response on an RB25 - yes it would be less linear on RB20, with a fierce rush of boost.
Price is $1500, located in Sydney. Post here or PM please.
*edit* the copper crush washers are new & unused.
Edited by BigDatto
https://www.sau.com.au/forums/topic/179304-hks-gt2535-bb-turbocharger/
