1x HKS 2835R .61 zorst housing, t2, externally gated. Bit of shaft play: $1350
Heres the numbers on the ID tag:
DF 01 01 J
GT2835R - 56T
700177-4
Also got 4sale:
1x Autometer/Autogauge 5" Black faced Tacho $200
1x Set of S14 S1 rear lights with centre garnish $150
1x Set of Brand New S14a rear lights with centre garnish $900 SOLD
1x R33 S1 Power FC No hand controller(still in car) $950 SOLD
1x Turbosmart ProGate 45mm external gate, like new $350 SOLD
1x R33 Vented Factory bonnet $500 SOLD
1x Bride Ergo 2 (Brand New, no rails) $950 SOLD
1x R33 boot with Topstage stealth wing $350 SOLD
Make me an offer peeps I need this stuff outta here!
Can deliver @ buyers expense.
Bodykit parts still on car 4sale, prices firm (Refer to pics below)
Set of Topstage R33 Sideskirts $200
R33 Series 2 Topstage bar(as u can see it fits S1 also) $250
R33 Topstage Rear Bar $250
Set of Topstage R33 +20mm Wider vented front guards $300
Set of Topstage R33 GTR fibreglass rear guards +35mm or so $300
All body parts on hold ATM.
Car is also 4sale peeps :D
Quick stats:
Custom mix grey(has a subtle khaki kind of green through it)
-various plastic interior pieces colourmatched
Fully kitted, with wider front(+25mm) & rear(+35mm) guards
19inch "Chromies" :P
145,000kms
Sunroof
5spd with heavy duty exedy clutch
FMIC
Full stainless zorst
GTR fuel pump
JVC MP3 deck, pioneers in doors and clarions on shelf
-amp wiring run through car, from deck 2 boot, so its ready for buyer
HKS boost guage on steering column, which has quick release
Momo steering wheel
EL Dash Cluster
20k or 16k without rims OBO
Thats with 11 months reg and RWC, when shes in for RWC ill also service her for new buyer!
Plates are NOT included at all.
Thats all I can think of atm, but hold tight for a lil till I organise a proper thread.
Will only do swaps(-/+ cash adjustments) with S14 series 1 or S15 Varietta!!
Edited by ABuSD
https://www.sau.com.au/forums/topic/179650-vic-hks-2835r/
  • 4 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
