  • Replies 64
Posted Images
  • 5 months later...
would u by any chance have the black plastic seal thingy on the outside of the left hand door? i can do pickup im in SE suburbs too.
im not sure what it is you mean but is it the mould on top of the door??
pic and price for the hks super drager exhaust
also would you have driver side weather shield by chance?
thanks
yeah i want $170 and i have pics if you click on me and look at the post of it
sorry i dont have the weather shield.
hey mate could i come pick up the door
yeah ring me and you can come pick up
Idle air control on the back of the plenum if you have it??
Cheers
sorry no
Can u give me a price on the rear brake backing plates??? Cheers...
$30 each thanks
  • 3 months later...
  • 3 weeks later...
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
