hey guys,
i have had my gtr sitting for about a year and went to start her yesterday and she doesnt want to kick over??
anyways i checked everything out and 4 out of 6 of the coil packs were sitting in water (down where the plug is), looks like it has been sitting there a while too. so i got all the cr@p out and fixed that up.
also, the fuel has turned to varnish.. i took the filter out on the pump side to find out if i have any pressure. i turned the key and some fuel came out but not that much and then after about 4 seconds it started dripping like it was clogged? i turned it off and then back on and there was nothing still? waited 30seconds and redid it and pressure and then it died again!
im wondering if the pump is dead, causing it not to crank over? or could it be the spark plugs.. new iridums.
dan
Edited by Rude Carz
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/
  • Replies 46
ok, i just cleaned the lines that go prety much up to the reg..
i have checked the packs for spark.. all clear..
i have checked the packs with plugs on the end.. all clear..
so, its got fresh 98octane in it.. clean lines, tank, and pump.
what the hell else is there?
help!
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3280815
ok, injectors were fully flow tested and cleaned today, they were fully blocked..
still.. she is not cranking over, put some aerostart in the vac lines and she wanted to start but couldnt..
i am begining to think its the CAS. it might be stuffed or seomthing??? i dont believe i am getting any power to the injectors.
either that or the ECU is stuffed!
i need some advice here!!!!!!!!!
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285105
It may have fouled plugs, pull one out and see if there wet with fuel.
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285188
so i take it you're sure the injectors are firing properly now? maybe pull them out and take the cas off and give it a spin too verify that they are properly working..
after having the coil packs sitting in water for so long perhaps the springs that sit inbetween the bottom of the coil pack and the spark plug have become corroded, try checking them out :D
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285262
U need to remove an injector plug from the top of one of the injectors and insert a noid light in the plug.
If u are getting a signal from the ecu the light will flash,meaning if u have spark like u say its not likely
the ecu. Next step would be to check compression.
U may be able to purchase a noid light from repco etc or borrow one from your mechanic.
Good luck
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3285319
ok, just ran ecu diagnostic and got a 55 back.. so all is good there.. i dont understand???
i shot some aerostart in the vac line and it wants to crank over and splutters a bit and waht not..
i have pulled out the CAS and it is fine although i havent put the ign on a turned the sensor to see if there is injector pulse..
HELP
does anyone live in brisbane and would be able to help me out?? PLEASE!
dan
Edited by Rude Carz
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3308825
Mate trhis may sound silly but have you changed the fuel filter since you said it was blocked? If you really wana know, pull out your injectors, crank the car & see if they spray fuel. Maybe even one will do... Do the same with your plugs if you havent already
https://www.sau.com.au/forums/topic/180298-gtr-wont-start/#findComment-3309111
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
