Car Condition:
R33 GTR
Upgrades:
Tomei Fuel Pump, 700cc Sard Injectors
PowerFC/Blitz ID3 Boost Controller
Adj Cam Gears, Tomei 260° Poncams,
Trust Intercooler, Aluminium radiator with Oil Cooler
HKS GT-SS Turbos
Reason for Rebuild
About Mechanic fixed head gasket & fitted Cam Gears, fuel pump, HKS turbos, cams, water pump, timing belt, replaced hoses etc. However, it has been driving pretty rough and the compression in no1 was low. Drove around for months & months. Mechanic pulled engine apart & looks like the bolts on the ajdustable cam gears came loose on intake side & ignition became very advanced & lead to damaged valve (not to bad - compression down about 30 & not too much scoring. On the other hand Crank & Conrods are in good condition.
Current Shopping List:
- Block Machined etc.
- New Clutch - Current is a Nismo Gmax thing & is pretty on/off looking at something easier to drive as 99% of driving is on streat - mainly to & from work. Looking at Jim Berry.
- ARP 2000 Rod Bolts
- Nissan N1 Oil Pump with collar
- ACL Big end & Main bearings (SR20 bigend bearings & RB30 Main Bearings)
- CP Pistons and rings
- Tomei Head Gasket Set - with restrictor
Now as 99% of driving is on the street and fairly boring - wondering if I should get baffles, etc.
Any advice is awesome,
Cheers,
Pen
https://www.sau.com.au/forums/topic/180401-another-r33-gtr-rebuild/
If the bolts on the inake cam came loose, it couldnt advance anything let alone the ignition timing as thats driven off the exhaust cam.
ACL do rb26 big ends bearings
You wont need a crank collar, as the R33 cranks have a long drive already
Rest looks pretty good, although i would rebore the block to suit oversize pistons so you arent working with bores that have 10 yrs work.
whilst its apart be sure to fit the restrictor and a sump baffle and drill the sump webs. It may not be required with a restrictor but honestly for the 300 bucks they cost is it worth pulling the engine down again IF something happens.
Id also be fitting ARP head studs if you plan to run a metal gasket and be sure to have the block deck and head surface checked/ground
agreed but when building one I still like to cover ALL bases and fit a baffle kit.
I ran my old RB26 for 2 years with no baffle and it never suffered oil issues (besides the leaks) it seem more circuit time than most as well.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
