Hi all,
My mates Red R31 was stolen last night
its a series 3 lowered on stogies.
Its turbo but has no BOV and runs low boost so you may only hear a slight turbo spooling whistle noise as it goes past.
If you have seen this car about please reply.
It was stolen from montrose, neer glenorchy.
Edited by Finny
https://www.sau.com.au/forums/topic/180600-stolen-r31-s3-turbo-red/
Cheers Brad,
It was a sleeper, S3 Executive AUTO - RB30e+t, she's stock looking - $15 super cheap hub caps, bulging tyres (215's on 6"rim), recently resprayed but paint a bit flakey around doors etc, has a rotary style dump exhaust, car is fairly low. If you hear it, its got a really quiet exhaust note, really can only hear whoosh and spool, has a really quick soft flutter (small side mount cooler)
Photo;
ta
-Dan
wtf dan? where was it parked when it got taken? thats rubbish
Yeah, In Montrose - a street off the main road, it was on the side of the road under a street light, with a steering lock on...
haven't got the "found torched" call yet - heres hoping...
red books only worth $2200 tops :nyaanyaa:
I'll take the ghetto way home and have a look around, that sucks
  • 2 months later...
Well To close this up.
The car was never found.
It was thought to have been sighted in new Norfolk, however red executives some how all look the same.
The police haven't heard anything at all about it.
And my insurance company Suck, however the claim has been made and closed.
R.I.P poor red Car :mellow:
Edited by bambi_1319
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
